Up until this year, I used the cheap nozzles - the original that came with my Ender 3, and both the ones that were supposedly by Creality and appeared identical to it, and similarly cheap ones off Amazon. I never had any problem with them that I attributed to nozzle quality, but I went through them fairly quickly since they were so cheap, just swapping one out if it got a lot of buildup that was hard to clean off rather than bothering to clean it well. I would say they are perfectly usable.
However, if you're already used to paying more for a nozzle, I would strongly recommend ditching plain nozzles and going with the Bondtech CHT. The performance and quality improvement from it is drastic. It gives more improvement to flow than going from a standard size block to a volcano size block (see Stefan's tests on CNC Kitchen), and a lot less backpressure, so you can get by with lower values for Pressure Advance/Linear Advance, which put less stress on the extruder and get more consistent extrusion. In terms of ratio of printing performance boost to price (not to mention ease of installation), it's probably the single best upgrade you can make to a printer. And while it's not a special durable material, it is coated, which makes it a little bit better than plain brass.
