I am new to 3D printing. I had a big issue with the full hotend: thermocouple broke, the fan broke, plastic everywhere... (I don't really know why as hundreds of prints were good before)
Anyway, I decided to replace the full hotend (2 fans + thermocouple + cartridge). I have the issue of nozzle temp. rising to max value very fast (250 °C defined as max temp. to not exceed in my printer setup). PID autotune failed because of this.
I checked my printer, it is a 24 V supply (Tevo Tornado)! When I measure the resistance of the old cartridge, it is 40 Ohms and the new one is 4 Ohms. I would like to replace it but really don't know how to do with the 8-pin connector...
I don't know if the new hot end is for 12 V or for 24 V power supply but I thought it was not a problem anyway with my 24 V supply... I am completely lost here...
Could you help me with this issue?
saphozzo
A heater cartridge with a resistance of 4 Ohms (including the cables) is designed for use with a 12 Volt system. When installed on a 12 Volt system, it will have a power output of around 40 Watts. This will increase to 160 Watts if it is installed on a 24 Volt system.
Mick
  • 3,002
  • This means I can burn my system, right ? Is there any possibility to adapt this one ? I thought to use a 12 V on a 24 V was possible, but not the opposite. – saphozzo Apr 19 '22 at 20:17
  • @saphozzo Yes. That power level is dangerous. Use a 24V heater cartridge. – Mick Apr 19 '22 at 23:11
