Okay, this one is a bit weird as everything else on the printer (for the most part at least...) is working perfectly. Some minor adjustments here and there are needed but this issue has shown up recently since adding a BLTouch.
After starting the print my printer regardless if I have it set up to wipe or not will them run the BLTouch (NOT the extruder, ONLY the BLTouch) into the side of the print bed. All of my offsets seem to be correct but for whatever reason, I can't seem to figure out what to correct to make this not run into the side of the bed as admittedly after the collision it prints fine! Any ideas?
(I have provided a video to give a better idea as to what exactly is going on as there are similar issues however they don't quite match my situation from what I've seen)
