I created some Marlin versions for Creality and Anycubic printers. Now I have a problem and want to ask if someone can help me, give some tips or something else.
Printer: i3 Mega Anycubic I use the 2.0.bugfixes and took a configuration example from 2.0.8.1
The firmware works, but the movement/travel from XY is very slow when I go to the next probe_point.
Homing works great.
Only the probe_manually does not work.
Steps to Reproduce:
  1. Try Disable Auto bed
  2. set up XY_PROBE_FEEDRATE (100*60) higher
  3. set HOMING_FEEDRATE_MM_M higher
  4. disable AUTO_BED_LEVELING_BILINEAR
Nothing helps
It looks like the xy_probe_feedrate would not be interpreted...
andy
  • Does [this](https://3dprinting.stackexchange.com/a/13999) answer your question? Note that parameter names change over time `SPEED` now seems to be `FEEDRATE`, see [`Marlin/src/inc/SanityCheck.h`](https://github.com/MarlinFirmware/Marlin/blob/ee26fd0e0559d7f2d86b11b5552eaf9c9ff3174c/Marlin/src/inc/SanityCheck.h). – 0scar Nov 24 '21 at 16:21
  • @oscar Thank for your answer. I think it doesn't help, because i already use the new name "Feedrate" and not the old declaration "Speed". I hope i understand you. – andy Nov 24 '21 at 20:16
