When considering enclosures able to reach higher chamber temperatures, insulation is essential to keep the heater power low.
Typical insulation materials are not transparent: cork (fire retardant, good for the inner hot side), rock wool, styrofoam panels, aluminium insulating panels (aluminium walls with foam in between).
Still, most of the time it's preferable to have one side of the enclosure transparent, to see what is happening inside without having to use a webcam (which may not work well or which may have a reduced lifespan when operated at 60-80 °C, due to capacitors and thermal noise in the sensor).
Rock wool, styrofoam panels and cork all offer about 0.032-0.038 W/(m K) thermal conductivity. In other words, a panel which is 50 * 50 * 1 cm will require about 0.85 W per each °C of temperature increase, or 8.5 W per 10 °C. A cubic 50 * 50 * 50 cm enclosure 2 cm thick would require 26 W to increase the inner temperature by 10 °C.
Replacing just one side with a transparent acrylic panel 3 mm thick would push the power requirement to about 190 W for every 10 °C of temperature increase, therefore finding a transparent insulation would be quite interesting.
What are the options to have a transparent, but still reasonably insulating, panel?
