I have very strange problem. Motors X and Z are messing up somehow. I mean if I try to home X only, Z moves also. And vice-versa. Y motor homes and moves normally.
Board is stock E3v2 v4.2.2 with TMC2208. With Marlin everything is OK.
Also, I'm not sure if it's important, but I have compiled firmware 3 times and all 3 are different in size - 20424 bytes first, 20540 bytes second, and 21172 last. All with the same settings -> STM32F103, 28kbit bootloader, com only (USB, CAN disabled).
Heaters seem to work too.
Video (I'm not sure how to add a video window here)
Here is my config for motors:
[stepper_x]
step_pin: PC2
dir_pin: PB9
enable_pin: !PC3
microsteps: 16
rotation_distance: 40
endstop_pin: ^PA5
position_endstop: 0
position_max: 225
homing_speed: 50
[stepper_y]
step_pin: PB8
dir_pin: PB7
enable_pin: !PC3
microsteps: 16
endstop_pin: ^PA6
position_endstop: 0
position_max: 225
homing_speed: 50
[stepper_z]
step_pin: PB6
dir_pin: PB5
enable_pin: !PC3
microsteps: 16
rotation_distance: 8
endstop_pin: ^PA7
position_endstop: 0.0
position_max: 250
Minkoff
  • You should probably create an issue about this on the Klipper Github (https://github.com/KevinOConnor/klipper/issues) Maybe something about the shared enable pins? The HAL itself for the F103 works fine from my experience. Make sure your `kinematics:` in the `[printer]` section is set to `cartesian` – towe Jun 15 '21 at 07:05
  • Don't open a ticket on Github, read the documentation: help requests go to the Discord channel. – FarO Jun 15 '21 at 08:48
  • Also, check connections: maybe you inverted some cables. – FarO Jun 15 '21 at 08:54
  • "Make sure your kinematics: in the [printer] section is set to cartesian" Thanks, that help! – Minkoff Jun 15 '21 at 12:07
