You can't print a LEGOTM Brick, because you are not Lego System A/S. The best you can do is print a brick that is compatible with LEGOTM bricks. Also note that Lego Systems A/S has more than 600 US design patents, which might interfere with the legality of manufacturing bricks in the US.
The original bricks are made from ABS and made with a very tight tolerance and uses the inherent flexibility of the material to create a friction fit. However, Resin prints do lack the required mix of sturdyness and flexibility and thus can't create the required friction fit.
In other words: You can't make bricks that are compatible with LEGOTM bricks with a resin printer based on the material properties.
