What fan speed should I use with PLA? Do I need to manually set the fan speed in ‘Control’?
Also, on the filament cartridge Bed Temp is listed: "No heat/60-80 °C". Does this mean heating the bed is optional?
Bed heating is not required when printing in PLA. But if it is an option and you would like to heat the bed, I would not go above 70/80 °C for PLA. As far as fan speed, I would go 90-100 % especially if the bed is heated.
The answer is that it depends on the hotend temperature the area of the printed layer and the effectivity of the fan. It is best to print some test prints to find the optimum for your printer. E.g. prints with overhangs/slanted object are good tests for this. Normally a Bench y is not a calibration object, but the bow of the Benchy is an example, incorrect temperature (too hot) and too few cooling will result in the bow sagging out.
No, the slicer can schedule the cooling speed percentage for you.
Yes, PLA doesn't shrink much, so it doesn't necessarily need to be heated up to the glass transition temperature (temperature at which the filament becomes soft) of the plastic. It does require to take extra measures to get it to stick to the bed surface.
