I installed MKS Gen L V2.1 with TMC 2209 drivers to my Creality Ender-3 printer and updated the software to marlin 2, the stepper motors are getting extremely hot. What should i due to resolve this problem. The following Code is from the configuration_adv.h file showing the currents.
    #if AXIS_IS_TMC(X)
    #define X_CURRENT       800        // (mA) RMS current. Multiply by 1.414 for peak current.
    #define X_CURRENT_HOME  X_CURRENT  // (mA) RMS current for sensorless homing
    #define X_MICROSTEPS     32    // 0..256
    #define X_RSENSE          0.11
    #define X_CHAIN_POS      -1    // <=0 : Not chained. 1 : MCU MOSI connected. 2 : Next in chain, ...
  #endif
  #if AXIS_IS_TMC(X2)
    #define X2_CURRENT      800
    #define X2_CURRENT_HOME X2_CURRENT
    #define X2_MICROSTEPS    16
    #define X2_RSENSE         0.11
    #define X2_CHAIN_POS     -1
  #endif
  #if AXIS_IS_TMC(Y)
    #define Y_CURRENT       800
    #define Y_CURRENT_HOME  Y_CURRENT
    #define Y_MICROSTEPS     32
    #define Y_RSENSE          0.11
    #define Y_CHAIN_POS      -1
  #endif
  #if AXIS_IS_TMC(Y2)
    #define Y2_CURRENT      800
    #define Y2_CURRENT_HOME Y2_CURRENT
    #define Y2_MICROSTEPS    16
    #define Y2_RSENSE         0.11
    #define Y2_CHAIN_POS     -1
  #endif
  #if AXIS_IS_TMC(Z)
    #define Z_CURRENT       800
    #define Z_CURRENT_HOME  Z_CURRENT
    #define Z_MICROSTEPS     32
    #define Z_RSENSE          0.11
    #define Z_CHAIN_POS      -1
  #endif
  #if AXIS_IS_TMC(Z2)
    #define Z2_CURRENT      800
    #define Z2_CURRENT_HOME Z2_CURRENT
    #define Z2_MICROSTEPS    16
    #define Z2_RSENSE         0.11
    #define Z2_CHAIN_POS     -1
  #endif
  #if AXIS_IS_TMC(Z3)
    #define Z3_CURRENT      800
    #define Z3_CURRENT_HOME Z3_CURRENT
    #define Z3_MICROSTEPS    16
    #define Z3_RSENSE         0.11
    #define Z3_CHAIN_POS     -1
  #endif
  #if AXIS_IS_TMC(Z4)
    #define Z4_CURRENT      800
    #define Z4_CURRENT_HOME Z4_CURRENT
    #define Z4_MICROSTEPS    16
    #define Z4_RSENSE         0.11
    #define Z4_CHAIN_POS     -1
  #endif
  #if AXIS_IS_TMC(E0)
    #define E0_CURRENT      850
    #define E0_MICROSTEPS    32
    #define E0_RSENSE         0.11
    #define E0_CHAIN_POS     -1
  #endif
Thanks.
Rayan
  • 91
    I'm not familiar with TMC 2209s but [I've read](https://www.electronicsweekly.com/blogs/engineer-in-wonderland/tmc2209-number-going-hear-3d-printing-2019-06/) that Trynamic's steppers run hot normally. – Rykara Apr 05 '21 at 17:13
I notice that in "configuration_adv.h" for the BIGTREETECH-SKR-mini-E3, which uses TMC2209 drivers, the similar section has:
#if HAS_TRINAMIC_CONFIG
  #define HOLD_MULTIPLIER    0.5  // Scales down the holding current from run current
  #define INTERPOLATE       true  // Interpolate X/Y/Z_MICROSTEPS to 256
  #if AXIS_IS_TMC(X)
    #define X_CURRENT       580        // (mA) RMS current. Multiply by 1.414 for peak current.
    #define X_CURRENT_HOME  (X_CURRENT/2)  // (mA) RMS current for sensorless homing
    #define X_MICROSTEPS     16    // 0..256
  #endif
  #if AXIS_IS_TMC(X2)
  #endif
  #if AXIS_IS_TMC(Y)
    #define Y_CURRENT       580
    #define Y_CURRENT_HOME  (Y_CURRENT/2)
    #define Y_MICROSTEPS     16
  #endif
  #if AXIS_IS_TMC(Y2)
  #endif
  #if AXIS_IS_TMC(Z)
    #define Z_CURRENT       580
    #define Z_MICROSTEPS     16
  #endif
  #if AXIS_IS_TMC(Z2)
  #endif
  #if AXIS_IS_TMC(Z3)
  #endif
  #if AXIS_IS_TMC(Z4)
  #endif
  #if AXIS_IS_TMC(E0)
    #define E0_CURRENT      650
    #define E0_MICROSTEPS    16
  #endif
  #if AXIS_IS_TMC(E1)
    #define E1_CURRENT      800
    #define E1_MICROSTEPS    16
    #define E1_RSENSE         0.11
    #define E1_CHAIN_POS     -1
  #endif
In the reddit thread Stepper driver current settings?, user brewc found that the stepper motors drivers supplied with the Ender 3 specify peak (maximum) current whereas the TMC drivers specify RMS current.
So, you probably want to change the current settings to those in the above .h file.
Of course, in the spirit of changing almost everything on an Ender 3, you could also swap for stepper motors with a higher current specification and/or add heatsinks to the motors.
Andrew Morton
  • 314
  • Thank you so much for the comment. Unfortunately, I tried what you have stated in your answer but nothing changed the motors are very hot. Do you have another suggestion? – Rayan Apr 10 '21 at 16:02
  • @Rayan From a quick google, I think a relevant question is: are the "jumper caps" installed so that the TMC2209 drivers are using SPI control? – Andrew Morton Apr 10 '21 at 16:16
  • I'm so sorry but I do not know what is the meaning of SPI control?. I'm relatively new regarding 3D printers. – Rayan Apr 10 '21 at 16:39
  • @Rayan [SPI](https://en.wikipedia.org/wiki/Serial_Peripheral_Interface) is a way for parts of a system to communicate. As no-one with experience of that board with those drivers is replying here, I'll point you to another reddit post: [How to setup tmc 2209 uart on mks genl v2.1?](https://www.reddit.com/r/3Dprinting/comments/jwkz4a/how_to_setup_tmc_2209_uart_on_mks_genl_v21/) – Andrew Morton Apr 10 '21 at 17:13
  • I have solved the x, y, and z axes problem by putting the UART jumper. but I couldnt solve the dual-axis problem, when putting the UART jumper the noise increase and the temperature doesn't dissipate and they become out of phase! – Rayan Apr 10 '21 at 20:36
