My problem is that the BLtouch doesn't probe the whole bed, in which the probe starts from the left edge and stops at the middle of the bed. I'm using Marlin 2 software and this the code in the configuration.h file:
  #define BLTOUCH
 * Touch-MI Probe by hotends.fr
 * This probe is deployed and activated by moving the X-axis to a magnet at the edge of the bed.
 * By default, the magnet is assumed to be on the left and activated by a home. If the magnet is
 * on the right, enable and set TOUCH_MI_DEPLOY_XPOS to the deploy position.
 * Also requires: BABYSTEPPING, BABYSTEP_ZPROBE_OFFSET, Z_SAFE_HOMING,
 *                and a minimum Z_HOMING_HEIGHT of 10.
//#define TOUCH_MI_PROBE
#if ENABLED(TOUCH_MI_PROBE)
  #define TOUCH_MI_RETRACT_Z 0.5                  // Height at which the probe retracts
  //#define TOUCH_MI_DEPLOY_XPOS (X_MAX_BED + 2)  // For a magnet on the right side of the bed
  //#define TOUCH_MI_MANUAL_DEPLOY                // For manual deploy (LCD menu)
#endif
// A probe that is deployed and stowed with a solenoid pin (SOL1_PIN)
//#define SOLENOID_PROBE
// A sled-mounted probe like those designed by Charles Bell.
//#define Z_PROBE_SLED
//#define SLED_DOCKING_OFFSET 5  // The extra distance the X axis must travel to pickup the sled. 0 should be fine but you can push it further if you'd like.
// A probe deployed by moving the x-axis, such as the Wilson II's rack-and-pinion probe designed by Marty Rice.
//#define RACK_AND_PINION_PROBE
#if ENABLED(RACK_AND_PINION_PROBE)
  #define Z_PROBE_DEPLOY_X  X_MIN_POS
  #define Z_PROBE_RETRACT_X X_MAX_POS
#endif
// Duet Smart Effector (for delta printers) - https://bit.ly/2ul5U7J
// When the pin is defined you can use M672 to set/reset the probe sensivity.
//#define DUET_SMART_EFFECTOR
#if ENABLED(DUET_SMART_EFFECTOR)
  #define SMART_EFFECTOR_MOD_PIN  -1  // Connect a GPIO pin to the Smart Effector MOD pin
#endif
 * Use StallGuard2 to probe the bed with the nozzle.
 * Requires stallGuard-capable Trinamic stepper drivers.
 * CAUTION: This can damage machines with Z lead screws.
 *          Take extreme care when setting up this feature.
//#define SENSORLESS_PROBING
// For Z_PROBE_ALLEN_KEY see the Delta example configurations.
 * Z Probe to nozzle (X,Y) offset, relative to (0, 0).
 * In the following example the X and Y offsets are both positive:
 *   #define NOZZLE_TO_PROBE_OFFSET { 10, 10, 0 }
 *     +-- BACK ---+
 *   L |    (+) P  | R <-- probe (20,20)
 *   E |           | I
 *   F | (-) N (+) | G <-- nozzle (10,10)
 *   T |           | H
 *     |    (-)    | T
 *     O-- FRONT --+
 *   (0,0)
 * Specify a Probe position as { X, Y, Z }
#define NOZZLE_TO_PROBE_OFFSET { -43.5, -9, 0 }
// Most probes should stay away from the edges of the bed, but
// with NOZZLE_AS_PROBE this can be negative for a wider probing area.
#define MIN_PROBE_EDGE 20
// X and Y axis travel speed (mm/m) between probes
#define XY_PROBE_SPEED 800
// Feedrate (mm/m) for the first approach when double-probing (MULTIPLE_PROBING == 2)
#define Z_PROBE_SPEED_FAST HOMING_FEEDRATE_Z
// Feedrate (mm/m) for the "accurate" probe of each point
#define Z_PROBE_SPEED_SLOW (Z_PROBE_SPEED_FAST / 2)
I have tried changing the > #define MIN_PROBE_EDGE 20 value but nothing change.
Also this is the configuration_adv.h code:
#if PROBE_SELECTED && !IS_KINEMATIC
  #define MIN_PROBE_EDGE_LEFT MIN_PROBE_EDGE
  #define MIN_PROBE_EDGE_RIGHT 15
  #define MIN_PROBE_EDGE_FRONT MIN_PROBE_EDGE
  #define MIN_PROBE_EDGE_BACK MIN_PROBE_EDGE
#endif
I also have tried changing these values but unfortunately, nothing seems to work.
Rayan
  • 91
  • What is your probe actually doing when you run `G29`? – Rykara Apr 05 '21 at 17:06
  • Have you seen this question: [How to set Z-probe boundary limits in firmware when using automatic bed leveling?](https://3dprinting.stackexchange.com/questions/8153/how-to-set-z-probe-boundary-limits-in-firmware-when-using-automatic-bed-leveling/)? Your probe is pretty far to the left, this is subtracted from the right to prevent damaging the printer. – 0scar Apr 07 '21 at 13:19
  • Thank you all for your contributions, I found that I had to reset the mainboard and upload the new code so that the new changes could apply. – Rayan Apr 10 '21 at 16:05
Answered by OP, copied from a comment on the question…
