I have an Ender 3. I want to add an emergency stop button. Ideally it’ll plug in to the printer’s micro USB port and run the M112. I use default firmware and don’t plan to change it thanks.
The most effective way to effectuate an emergency stop is to pull the plug or turn the printer off. An alternative is a software stop using a print server program like e.g. OctoPrint.
Indeed M112 is capable of stopping the printer:
M112is the fastest way to shut down the machine using a host, but it may need to wait for a space to open up in the command queue. EnableEMERGENCY_PARSERfor an instantaneousM112command.
In order to use emergency stop functionality, you need a firmware capable of doing an emergency stop by having this enabled in the Configuration_adv.h printer configuration file, otherwise it will have to await the queue to be emptied first. I doubt if this is standard enabled in your default firmware (the Marlin default is disabled).
From Marlin's Configuration_adv.h:
* Emergency Command Parser
* Add a low-level parser to intercept certain commands as they
* enter the serial receive buffer, so they cannot be blocked.
* Currently handles M108, M112, M410, M876
* NOTE: Not yet implemented for all platforms.
//#define EMERGENCY_PARSER
Please note that this might not be implemented; it has not been implemented for all platforms.
An earlier question "Can G-code scripts be run automatically on inserting an SD card when using Marlin Firmware?" has an answer that hints to changing the sources on SD card insertion. In your case the USB needs to be monitored, and it a signal is detected the printer stopped.
So, since:
without modification of your firmware it is not possible to do what you want. But, there are perfectly viable options mentioned and available to do what you want (executing an emergency stop). Alternatively you could even use a (n Arduino powered) relay to cut the power based on the signal you want to send.
- 32,029
- 59
- 135
What about prolonging one of power cables (a ground preferably) to the front panel, and mount there a bueatiful red, normally connected, emergency button on this wire? Then you press it and power is momentarily detached. – octopus8 Mar 16 '21 at 16:02
Easiest way would probably be shorting 5V to ground with your button. How good your board will handle that depends on the board though. – towe Mar 17 '21 at 08:31
I just thought of breaking a ground wire incoming from power supply to the board. So after button press, the powering circuit gets open and there is no power provided to the board. Reboot-like. – octopus8 Mar 17 '21 at 08:51
