I have an Ender 5 pro and upgraded from the magnetic bed to the glass version. I print with Prusament PLA on 65 °C bed temp and 220 °C extruder temp. I measured that the glass surface has ~58 °C in the center and ~56 °C on the corners. That should be in the specs of the spool which has a printed recommendation of 50 +- 10 °C for bed and 215 +- 10 °C for extruder temps.
Now I also have a BLTouch and use the TH3D firmware so Z offsets should work correctly and are done with the Z offset wizard present (nozzle touching the bed).
The problem I currently have is that the first layers have "lifts" in them. Also, it seems that the layer itself is not 0.2 mm everywhere. It's close to 0.23 mm on the edges but on the inner there are variances up to 0.36 mm.
Currently, I slice with Cura 4.8.0 on Standard Quality 0.2 mm
How do I get rid of the lifts and irregularity in the layer? Is it a problem with the bed?
