I have PLA and PETG filament.
I hear that 3D filament absorbs water and causes problems when printing but after printing they can be used with water and they are water proof.
So my question is why is it different after printing/what has changed to make it now waterproof?
  • Is PETG waterproof or does it absorb water?
  • Is there a limit on how much water PETG can absorb or will it keep going until it splits and turns to mush?
Yolo Gamer
  • 23
Filament that absorbs water prior to printing is subject to boiling temperatures as it passes through the heater block. In extreme cases, steam will be visible and a spitting sound will be heard. The filament will expand as the water exits, causing multiple structural and printing problems.
Once printed, dry filament may absorb water from the atmosphere, but is unlikely to be subject to boiling temperatures.
Waterproofing as a general consideration usually means the ability to keep water out, which is possible if the model is sealed and some printing conditions will adhere each layer well enough to the previous one to provide floating-type waterproofing.
PETG is hydroscopic, which means it will absorb moisture from the air. When printed properly (layer adhesion), the model can be waterproof.
These terms are independent and should not be used interchangeably.
  • How can it be waterproof and absorb water at the same time? – Yolo Gamer Feb 10 '21 at 01:32
  • Also wouldn’t the print split between the layers if it absorbed too much water – Yolo Gamer Feb 10 '21 at 01:33
  • If the model is going to absorb enough moisture to split layers, it's been immersed for far too long and under extreme pressure. 3D models are used in radio control boating with no problem. One should seal or otherwise coat a boat to ensure that any gaps are closed. – fred_dot_u Feb 10 '21 at 01:52
  • Would it work as a bath tub plug/a tap attachment/hose nozzle or would that just not be possible with PETG alone – Yolo Gamer Feb 10 '21 at 02:10
Let's distinguish first three things:
  • Hygroscopic behavior. The ability of a substance to absorb water. Salt is very Hygroscopic.
  • Watertight open-shell. A boat is watertight against water from below. But you can pour water into it. Putting a lid on seals such a body somewhat, but the gap allows water to seep in.
  • Watertight closed-shell. A sphere is water tight against water from all sides. You can not pour water into it, no lid needed.
Now, hygroscopic behavior of filament has can create a huge hazzle when printing: Waterlogged filament creates lots of problems, like spazzing, steam, foaming and others. This can result in a watertight designed print being printed in a gappy fashion or result in lack of strength or many other results.
Watertightness of a shell - open or closed - is primarily a result of the design and well fused lines. In my experience, 2 shells can be watertight, 3 shells upwards is almost always watertight. The main problems are with tops, where I experienced that the minimum tops and bottom layers need to be 4, better even 5. But this is dependant on your print quality - and you might need more or less dependant on your settings.
Under stress, like in an RC boat hitting into waves, the inter-layer bonds are the ones that would break first, breaking the shell likewise. To strengthen both the shell and ensure water tightness, polymer lacquers like acrylic paint, guitar lacquer or even epoxy resin (2-component epoxy resin is a very common glue) have been used successfully to create much strengthened and polished surfaces in RC projects. But you don't need to go through these steps unless you really want to.
After printing, a hygroscopic filament still undergoes the same processes and might undergo strength shifts. Sintered-Nylon for example might become heavier and softer if waterlogged. Such material also can't be frozen, the contained water can destroy the print.
For a bath-plug, I just would print the item as a "solid" body from TPU - TPU is after all the opposite of Hygroscopic: it's Hydrophobic. The next best "easy" material is ABS (as you can seal the surface using a little acetone vapor and can withstand 80 °C water for some time without deforming), then PLA (it's barely hygroscopic, but does not like hot water), and likewise PETG will do for some time, possibly better with the heat. Unless you put it in a freezer, it will keep the water in the tub long enough to take a bath.
  • But would petg work instead of tpu because I don’t have the money for epoxy or tpu filament. Also apparently tpu is not food grade/food safe so if I use it for a bath plug it can be harmful to the body – Yolo Gamer Feb 10 '21 at 13:53
  • I'd prefer PLA for a bathplug (it's less hygroscopic), but PETG will work in a pitch. Just print it as solid as possible – Trish Feb 10 '21 at 13:55
  • Do you have any suggestions on a food grade sealer for prints because I have no knowledge on what to get. I have heard epoxy but I can find one that is food grade – Yolo Gamer Feb 10 '21 at 14:03
  • You said it will keep the water In the tub long enough. Does that mean it will break after taking it out or does that mean it will be mostly fine because it is not used for long periods of time. Because I don’t want a print splitting and jamming something up – Yolo Gamer Feb 10 '21 at 14:15
  • as a *stiff* part, the seal will be less good than a *flexible* plug. Any material will work well enough if designed well. In regards to Food Grade: No, I have no suggestion for any brand. Also, Food grade certified food safe FDM printing is [**Hard.**](https://3dprinting.stackexchange.com/questions/6937/ender-3-is-capable-of-food-safe-printing) – Trish Feb 10 '21 at 15:34
The properties of the maternal are not what changes after you print. It is how you use the material. PLA and ABS prints aren't usually subject to +100 °C after printing.
When PLA absorbs moisture it becomes brittle. PLA filament will break when trying to print. Your PLA print may be thick enough so that brittle doesn't cause a problem. However, this can be a problem if you intend your PLA print to be flexible.
The main issue with PETG absorbing moisture is the water changing to steam in the extruder. PETG becomes soft and will distort with force applied at +100 °C; so generally moisture isn't a issue with PETG prints, due to application.
PLA and PETG absorb moisture, but do not dissolve in water. Usually what a person means by waterproofing is water won't seep through the layers of the material and leak out of a container. Note: most glass will absorb small amounts of moisture, but are still waterproof.
If one wants a hermetic seal this is a similar issue. One person printing hermetic prints said thicker layers make it easier to be hermetic. Thicker layers also tend to make the printer stronger, but can also give less detail in the print.
Perry Webb
  • 2,158
