I am using an Ender 3 (v1.1.4) with Marlin 1.1.X bugfix installed. Also BLTouch v3.1 is used. The probe is deployed once only while mesh bed leveling.
How can I make the probe deploy twice at every point? Where am I supposed to change the code for it?
Please explain in detail if possible as I am not familiar with the coding part?
boom_shiva
For the 1.1.x (1.1.9) bugfix firmware version, the multiple probing is defined in the configuration.h file.
// The number of probes to perform at each point.
//   Set to 2 for a fast/slow probe, using the second probe result.
//   Set to 3 or more for slow probes, averaging the results.
//#define MULTIPLE_PROBING 2
You should change the configuration to include the multiple probing by uncommenting the line:
Note that there is question: "Updating Marlin Firmware - Step by Step Guide" that shows how you should modify the sources.
How to compile and upload/install the compiled binary on your printer controller board depends on the controller board version and type.
