I was printing an object and it started to drag so I stopped it.
Went to move the Z-axis up so I could clear the bed and Z-axis would not budge. I switched the printer off and manually turned the motors to get the Z up. Cleared the bed, switched on and homed the printer. When it came to home the Z, BLTouch deployed and then nothing. Motors will not turn.
Things I tried:
- Recompiled the firmware (Marlin 2.0.x)
- Different motors - Motors were free from the printer, just resting on a desk so I know it's not binding or anything.
- Swapped stepper driver with a known working one.
Info about the printer:
- CR10s
- SKR1.4 Turbo board
- TMC2208 Steppers
- BLTouch
- Octopi to control the printer.
Output of M122
for the Z:
Recv: Z
Recv: Address
Recv: Enabled false
Recv: Set current 1000
Recv: RMS current 994
Recv: MAX current 1402
Recv: Run current 17/31
Recv: Hold current 8/31
Recv: CS actual 8/31
Recv: PWM scale
Recv: vsense 0=.325
Recv: stealthChop true
Recv: msteps 16
Recv: tstep max
Recv: PWM thresh. 0
Recv: [mm/s] -
Recv: OT prewarn false
Recv: triggered
Recv: OTP false
Recv: pwm scale sum 10
Recv: pwm scale auto 0
Recv: pwm offset auto 36
Recv: pwm grad auto 14
Recv: off time 4
Recv: blank time 24
Recv: hysteresis
Recv: -end 2
Recv: -start 1
Recv: Stallguard thrs
Recv: uStep count 40
Recv: DRVSTATUS Z
Recv: sg_result
Recv: stst
Recv: olb
Recv: ola
Recv: s2gb
Recv: s2ga
Recv: otpw
Recv: to
Recv: 157C
Recv: 150C
Recv: 143C
Recv: 120C
Recv: s2vsa
Recv: s2vsb
Recv: Driver registers:
Recv: Z 0xC0:08:00:00
Recv:
Recv:
Recv: Testing Z connection... OK
