I’m building my new 3D printer and I have a doubt. I’m using limit switches on the 3 axes, but only the MIN switches. I also have another three switches which I want to use as MAX switches. How can I do that? I mean, if I insert a specific measure of the plate in Marlin and than the extruded stops before of the limit of the plate due to the MAX endstop what will happen? What should I do, upgrade to MIN and MAX endstops or only keep the MIN ones?
Asked
Active
Viewed 944 times
You should see MAX endstops similarly as MIN endstops, or as an additional option to protect the printer:
- Similarly seen as MIN endstops, you would define in the firmware that you are using them to set a reference point at maximum values, your offsets and bed dimensions would be calculated from the MAX positions;
- You can configure the MIN endstops and have additional MAX endstops set beyond the bed size dimensions. If the printer would encounter a layer shift causing the nozzle to go beyond the printer (MAX) boundaries, the printer shuts down when the MAX endstop is triggered.
- 59
- 135
Ok, thanks. So i can’t use both of them in one axis? I think i’m going to use only the MIN ones – Valeri 0S Apr 27 '20 at 06:06
@Valeri0S As explained in the answer under 2. You can use them both. But don't put them at exactly at the maximum axis positions according the bed size, put them a little further, then they will act as safety stops in case of layer shifting occurrences. – 0scar Apr 27 '20 at 06:19
