I need to transport my FDM 3D Printer because I am moving.
What are the precautions that one should take?
Should I dismount the motors and axes?
I would definitively unplug the electronics as far as reasonable and fix the motors to the frame so they don't slide during transport.
Should I have a housing to avoid dust and other mechanical issues?
kamuro
  • 2,854
  • 42
Yes, fix the motors and any other loose/movable parts. Remove the bowden tube if it's there, and any other parts that are sticking out. Put the whole thing in a a bag to protect from dust, and put the bag in a box to protect it from getting beat up. Remember to calibrate it when you're ready to set it up again.
Dampmaskin
  • 202
    I just moved house, and here's what I did: 1) zip-tie moving carriages to a stationary position 2) pack up glass build plates in bubble wrap and boxes 3) remove filament and loose parts like spool holders and feed tubes 4) put the six 3d printers in the back of my SUV, with suitable straps through the frames to keep them from falling over. Worked fine. – Ryan Carlyle Jun 09 '16 at 19:36
  • sorry for OT, but: 6 printers? Wow. I see now why you call it 'a serious 3D printing addiction' ;) On topic: Thanks for the info, it could've been it's own answer, in my opinion. – kamuro Jun 10 '16 at 09:01
  • What is the reasoning for removing the bowden tube? Is it just to make the printer more compact and easy to handle during transport, or is it for "safety" reasons? – Tom van der Zanden Jun 14 '16 at 13:56
  • @TomvanderZanden: Just to make the printer more compact, and to avoid kinking the tube or putting too much strain on the mounting points for the tube. Better safe than sorry. (And at least with my Ultimaker the tube tends to always get in my face when I lift it.) – Dampmaskin Jun 14 '16 at 14:03
  • I also like setting them on a board to prevent flexing of the frame. My Prusa has a big plastic box I move it around in. A bit like a pelican box. Just dumb luck the top of the printer fits in a grove in the lid so it can't slide around. My Rostock gets set on it's back on 2 boards that straddle the center column so I don't put pressure on the rods. Support the whole printer to prevent flexing. Things like to shift forward in a vehicle so orient and protect with this in mind. (Protect from slamming on the brakes). – creuzerm Jun 17 '16 at 14:23
Transporting a 3D printer does not require special precautions.
Obviously you should package it to protect it from damage (but this depends on the mode of transportation and how sturdy your printer is; if you are just placing it in the back of your car with no chance of it bumping in to anything, no packaging is required at all).
It might be wise to secure the carriage(s) in place so they can't move around, but I would definitely not bother with unplugging anything (apart from the mains power, naturally). Leaving the motors plugged in means they will provide some holding torque, which might be advantageous to keep your axes from sliding around.
Dust is not too great of a concern, as 3D printers can handle it (to some degree) thanks to the seals included on linear bearings.
Tom van der Zanden
  • 14,588
  • I would unplug the motors to avoid induced voltages on the motor drivers from sliding axes (which would be fastened anyway, - so that's already contrary to my argument). I've heard that certain drivers are sensitive to induced voltages... – kamuro Jun 10 '16 at 08:59
  • @kamuro Do you have any source stepper drivers are sensitive to this? It seems rather unlikely to me, given that they already have to handle large voltage spikes during normal operation. – Tom van der Zanden Jun 10 '16 at 10:41
  • It was mentioned in a reprap forum, but I can't find it anymore. Some few people were reporting about burning their stepper drivers by moving carrages by hand. You are right, I also found it hard to believe, but I'd rather be safe and not fry my drivers ;) – kamuro Jun 10 '16 at 12:49
-1
You just need to take basic security actions. like fixing all movable parts simple as that
Dan Boyko
