First, Ultimaker Cura estimated printing times are not necessarily accurate for non Ultimaker printers. For Ultimaker printers this is perfectly tuned, Cura estimates the printing times from experience for the UM3E correctly. Please look into question "How to determine real printing speed (tarantula/cura)?" which is relevant to this question and has an interesting accepted answer.
Second, changing the MAX accelerations will not work, you should increase the default acceleration:
From the TEVO Tarantula Marlin fork you read from the Configuration.h file:
* Default Acceleration (change/s) change = mm/s
* Override with M204
* M204 P Acceleration
* M204 R Retract Acceleration
* M204 T Travel Acceleration
#define DEFAULT_ACCELERATION 1000 // X, Y, Z and E acceleration for printing moves
#define DEFAULT_RETRACT_ACCELERATION 2000 // E acceleration for retracts
#define DEFAULT_TRAVEL_ACCELERATION 3000 // X, Y, Z acceleration for travel (non printing) moves
From the main Marlin source you will find:
#define DEFAULT_ACCELERATION 3000 // X, Y, Z and E acceleration for printing moves
#define DEFAULT_RETRACT_ACCELERATION 3000 // E acceleration for retracts
The TEVO Tarantula sources have lower default acceleration values, you could try to increase those.
