I'm doing some research on what types of LCD displays can be used to filter and pass UV light for resin curing - specifically in the context of building a DIY 3D SLA printer.
The community commonly uses the Sharp LS055R1SX03 module. Looking through the datasheet, there doesn't seem to be any information pertaining to the characteristics of the device when passing UV wavelengths. Is there something special about this module that allows it to filter/pass UV wavelengths compared to other common LCD displays?
Robby Wasabi
  • 111
Hmm I seen videos off people pealing filters off of lcd screens to let uv pass through.
I believe the sharp unit maybe popular because not all lcds have square pixels and have poor pixel alignment towards the edges, (the focus of the eye can only take in so much information why waste materials producing inperceptable rises in quality, much like having a 8k small screen unless the picture is static your hard pushed to notice difference).
There is also diffraction to think about, crystal size in the resin, oxygen membrane or delamination layer to stop cured resin sticking to lcd, I think there are projects of floating resin on another liquid (fluorinated oils work).
Even with better resolution(4k,) the voxel size does not increase in a linear manner, unless the uv light source is focused an colimated like in a lazer.
I don't know much its just info I've gleaned whilst browsing, I'm sure someone will correct any inaccuracies.
I am not an expert by any stretch but I hope this helps, but these are regular old TFT LCD screens. You can even get 4K ones and use them for the same process. You can for example pick up 4K displays such as the H546UAN01.0 and do the same with them.
Bob R
  • 121
