PET-G is the main filament I use. I can achieve high quality of my prints with my Prusa i3 mk3s printer. Recently however, I've recently changed my nozzle from the default 0.4mm to the 1.2mm. I watched the online video tutorial on how to do it properly and did the whole process carefully.
Temperature: 250 °C/100 °C Speed: max 200 %, but results are the same even all the higher ones . Layer height: 0.35 mm
With my first print (and the next ones too) on the new nozzle I noticed lots of under-extrusion with infill (holes). LOTS of stringing although I've increased retraction. What's the reason ?
StLuke5
  • 525
  • 16
  • What speed, layer height and temperature are you using? You have just increased the cross-section of the nozzle by 800%. It is possible that the hot end is not able to extrude the filament at the rate that you are requesting. – Mick Jul 10 '19 at 21:37
  • @Mick I'm sorry, I've forgotten to add this, I usually include such information. I will edit my question – StLuke5 Jul 10 '19 at 21:41
  • Can your hotend melt PETG at the rate you're printing? You need a **hardcore** hotend to take advantage of that nozzle size without really low speeds. Assuming you don't need the wall thickness, 0.4 can probably even print faster with a normal hotend. – R.. GitHub STOP HELPING ICE Jul 11 '19 at 00:09
  • "200%" doesn't seem like much of a valid speed - unless the Prusa i3 has some sort of default speed everyone is using? At the same layer height, you can only move 1/3 as quickly as with a 0.4 mm nozzle - your hot end has to melt *much* more plastic at the same speed. Since you also went to a layer height of 0.35 (with the default presumably being 0.2mm), you're now extrusing 5.25x as much plastic in the same time. Your hot end probably just can't keep up. – towe Jul 11 '19 at 08:09
  • @Towe Prusa says that speeds up to 200% are OK. But I'll try switching the layer height to 0.2mm – StLuke5 Jul 11 '19 at 10:28
  • @StLuke5 Well, 200% of what sort of default speed? That would have to be a figure of something like "40 mm/s" or "2400 mm/min" (in ancient slicers). – towe Jul 11 '19 at 10:46
  • Having struggled with PETG myself, using a V6 with a 0.4mm nozzle, I can say with a fair amount of confidence that printing lines 1.2mm across and greater at 0.35mm layer height, at feedrate faster than a snail's pace, is simply outside the capabilities of your hotend. That is an absurd amount of plastic to melt in that kind of time period. You'd probably benefit from upgrading to possibly a Volcano hotend if you want that kind of performance from your printer. – Nach0z Jul 13 '19 at 00:38
  • @Nach0z Thanks, decreasing the layer height to 0.2mm worked for me. – StLuke5 Jul 13 '19 at 18:24
Piecing this answer together from the comments on OP's post. Myself and R.. noted that a layer height of 0.35 mm, nozzle width of 1.2 mm, and a fairly high feedrate (200 % according to OP, no reference to what 100 % is), is an exceptionally large amount of plastic to try and melt through almost any hotend on the market except possibly the Volcano, or the high-throughput version of the Mosquito.
OP responded that lowering the layer height to 0.2 mm seemed to fix the issue. That's still an impressive amount of plastic, but it's a 43 % decrease in total flow compared to 0.35 mm layer height.
Nach0z
  • 876
    Addendunm: e3D Volcano and Supervolcano have doube/quadruple the meltzone length to gain access to extreme flow for extreme speeds. The only other type of extruder, that I could think of that manages this is a pellet type extruder, where the arbor is heated and offers similar access to high flow. – Trish Jul 14 '19 at 11:45
