I had a piece of filament break off in the tube and could not unload it so I removed the extruder and pulled out the piece. Reloaded filament and started to recalibrate. The head went to left and tried to keep going. It made a horrible thumping and would not stop until I turned the unit off. I then tried to home it, same result. Tried to reset to factory settings then home it and same result. Any ideas?
Asked
Active
Viewed 217 times
This can happen when the end stop of the X-axis (i.e. the minimum end stop on the left) has moved/bent/broken/un-connected.
Please look into this answer of question Flashforge Adventurer 3 - how to replace X-axis endstop. The X end stop is a module inside the print head, please look if the connector is dislodged or something.
- 59
- 135
